HS-USB in STM3240G-EVAL
Posted on June 11, 2014 at 22:36
I just got the STM3240G evaluation board and wanted to use it as a CDC USB device, for HS USB. I haven't had much success with ST's firmware so far. I generated the configuration files using the Cube application, and later also tried the CDC_Standalone example that is on the webpage for this kit. Unfortunately it doesn't enumerate successfully in Windows. I am using the Virtual Com Port driver for STM32. Please advise! Thanks, Umaid
