How to watch variables in CubeMX
tohru-sagayama
Posted on March 23, 2015 at 08:53
Hello.
I'd like to know how to refer values of variables.
My understanding is all of variables are seen in a variable scope when I stop a program, but at the moment, I can't look at some variables I defined.
Could someone teach me how to figure out the problem ?
takahasi
Posted on March 23, 2015 at 09:57
Use optimization level 0 (-O0).
joe
Posted on March 27, 2015 at 11:07
If using optimization Level 0(-O0) doesn't work you can try making the variables you want to watch volatile.
/*declaration*/
volatile uint8_t var;
You could also have a define specifically for debugging:
#define _DEBUGGING_
#ifdef _DEBUGGING_
#else
uint8_t var;
#endif
Level 0 shouldn't optimize out variables but I have seen it happen.
