How to use STM32070CB to achieve IAP?
磊茆.1
Peter BENSCH
You probably mean the STM32F070CB, right?
IAP = In Application Programming, which can be achieved using several mechanisms.
What is your expected workflow or the procedure to do an IAP?
/Peter
Same way as other STM32 and STM32F0xx devices. Look at some of the examples in the CubeF0 trees
STM32 IAP Application Note
http://www.google.com/search?q=STM32+IAP+Application+Note
https://www.st.com/resource/en/application_note/dm00161366-stm32-inapplication-programming-iap-using-the-usart-stmicroelectronics.pdf
https://www.st.com/en/embedded-software/x-cube-iap-usart.html
yes ,it's STM32F070CB
i want use usart receive upgrate data and save them in extern flash.
But when i use STM32F0xx standard peripherals library it can not remap Interrupt vector table.
Regards​
