2014-12-02 1:47 PM
I tried to send several frames through CAN of STM32F103R4 but i could only send one frame. Somebody know How to sende several frames?
#can #stm32f103r4 #can2014-12-02 4:01 PM
Pretty sure you can just send one after another.
[DEAD LINK /public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/transmit%20interrupt%20of%20CAN%20works%20well%20in%20loopback%20mode%20but%20vice%20versa%20in%20normal%20mode&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B¤tviews=1271]https://my.st.com/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=%2Fpublic%2FSTe2ecommunities%2Fmcu%2FLists%2Fcortex_mx_stm32%2Ftransmit%20interrupt%20of%20CAN%20works%20well%20in%20loopback%20mode%20but%20vice%20versa%20in%20normal%20mode&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B¤tviews=12712014-12-03 5:08 AM
First the obvious, do you have two nodes connected together? You cannot send data with just one node. Are both ends of the twisted-pair bus terminated? Is the second node receiving the message sent by the first node?
What are the contents of the error registers? You may be stopping due to a fault condition. Jack Peacock
