How to read 3 channel ADC with DMA
2016-01-13 7:16 AM
Hi
I'm using STM32f7 Discovery board.I want to read 3 channel adc with DMA.I currently run a single channel.But I could not run three channels. I want to use ADC3 Channel 6, Channel 7 and Channel 8 This is ADC config code/**
* @brief ADC configuration
* @param htim : ADC handle
* @retval None
static void ADC_Config(void)
ADC_ChannelConfTypeDef sConfig;
/*##-1- Configure the ADC peripheral #######################################*/
AdcHandle.Instance = ADC3;
AdcHandle.Init.ClockPrescaler = ADC_CLOCKPRESCALER_PCLK_DIV4;
AdcHandle.Init.Resolution = ADC_RESOLUTION_12B;
AdcHandle.Init.DataAlign = ADC_DATAALIGN_RIGHT;
AdcHandle.Init.NbrOfConversion = 3;
AdcHandle.Init.ScanConvMode = ENABLE; /* Sequencer disabled (ADC conversion on only 1 channel: channel set on rank 1) */
AdcHandle.Init.ContinuousConvMode = DISABLE; /* Continuous mode disabled to have only 1 conversion at each conversion trig */
AdcHandle.Init.DiscontinuousConvMode = DISABLE; /* Parameter discarded because sequencer is disabled */
AdcHandle.Init.NbrOfDiscConversion = 0;
AdcHandle.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_RISING; /* Conversion start trigged at each external event */
AdcHandle.Init.ExternalTrigConv = ADC_EXTERNALTRIG2_T2_TRGO;
AdcHandle.Init.DMAContinuousRequests = ENABLE;
AdcHandle.Init.EOCSelection = DISABLE;
if (HAL_ADC_Init(&AdcHandle) != HAL_OK)
/* ADC initialization Error */
/*##-2- Configure ADC regular channel ######################################*/
sConfig.Channel = ADC_CHANNEL_8;
sConfig.Rank = 1;
sConfig.SamplingTime = ADC_SAMPLETIME_3CYCLES;
sConfig.Offset = 0;
if (HAL_ADC_ConfigChannel(&AdcHandle, &sConfig) != HAL_OK)
/* Channel Configuration Error */
/*##-3- Start the conversion process #######################################*/
if(HAL_ADC_Start_DMA(&AdcHandle, (uint32_t*)&uhADCxConvertedValue[0], 3) != HAL_OK)
/* Start Conversation Error */
How do I make ADC channel settings in HAL libraries?
Thank you
2016-01-13 8:14 AM
Configure the pins, and add channels as Rank 1 thru 3
2016-01-13 9:42 AM
hi clive
I did not understand what I should do. I have configured the GPIO pins. GPIO_Pin_8, GPIO_Pin_7 and GPIO_Pin_6 is analog input. Settings are as follows.static void ADC_Config(void)
sConfig.Channel = ADC_CHANNEL_6;
sConfig.Rank = 1;
sConfig.Offset = 0;
sConfig.Channel = ADC_CHANNEL_7;
sConfig.Rank = 2;
sConfig.Offset = 0;
sConfig.Rank = 3;
sConfig.Offset = 0;
How do I do the Rank settings?
2016-01-13 9:47 AM
Ok, that looks like a good start, and the TIM2 is set to trigger these. At each trigger event the three conversions should occur one after the other.
2016-01-13 1:24 PM
hi clive
Thank you for the reply, Yes, I used to timer TRGO output. ADC is working on a single channel. But, 3-channel ADCs is not working. I could not run. Exactly what should I do? Thank you- Mark as New
2016-01-14 10:25 AM
Not sure, the HAL+F7 is not something I'm working on. You might want to dig into some of the board level examples provided with HAL/Cube.Maybe someone from ST can pick this up?Up vote any posts that you find helpful, it shows what's working..
2016-01-15 12:23 AM
Hi Clive
I solved the problem,DMA size should be sixfor three channels,But now I have another problem.ADC channels are affecting by each other.https://www.youtube.com/watch?v=NkiLlNQ1SH4
The final version of the ADC configuration code:/**
* @retval None
ADC_MultiModeTypeDef MultiMode;
HAL_ADC_Init(&AdcHandle);
sConfig.Rank = 1;
sConfig.SamplingTime = ADC_SAMPLETIME_480CYCLES;
sConfig.Offset = 0;
HAL_ADC_ConfigChannel(&AdcHandle, &sConfig);
/*##-3- Configure ADC regular channel ######################################*/
sConfig.Rank = 2;
sConfig.Offset = 0;
/*##-4- Configure ADC regular channel ######################################*/
sConfig.Rank = 3;
sConfig.Offset = 0;
/*##-5- Configure MultiMode Settings #######################################*/
MultiMode.Mode=ADC_MODE_INDEPENDENT;
MultiMode.TwoSamplingDelay=ADC_TWOSAMPLINGDELAY_20CYCLES;
HAL_ADCEx_MultiModeConfigChannel(&AdcHandle, &MultiMode);
/*##-6- Start the conversion process #######################################*/
HAL_ADC_Start_DMA(&AdcHandle, (uint32_t*)&uhADCxConvertedValue, 6);
Why it is affected by other each channel?
Thank you
2016-01-15 8:09 AM
Link doesn't work for me.
I guess you'd need to check the nature of the sources, and how rapidly they can charge the capacitor on the front end of the ADCUp vote any posts that you find helpful, it shows what's working..
2016-01-15 10:43 AM
Hi Clive,
I'm sorry, The link was deformed. I've updated the link.I don't think the problem is related to ADC Sample speed. Because it had the same problem when working slowly(10-15Hz)I need help. Thank you- Mark as New
2016-01-15 11:34 AM
Have you tried sampling pins tied to the power rails?
