how to g
Jessy J
25 REPLIES 25
Posted on May 27, 2018 at 13:23
https://community.st.com/0D50X00009XkY6TSAV
Use Google to find information and tutorials
Microsoft and GNU have PC based C compilers that can take C code and make executables/applications that run natively.
Jessy J
Posted on May 28, 2018 at 09:46
KI am using LWIP , STM32F4 and I want to iimplement an http web based on netconn API in the board.
I activated httpd from CubMX, I downloaded makefsdata.exe from internet and I generated with it the fsdata.c file..
In the fs.c generated by CubMX there is error in the fnction fs_open
in the programm of the http I am using I wrote this
file = fs_open(''/STM32F4xx_files/stm32.jpg'');
In fs.c file
err_t
fs_open(struct fs_file *file, const char *name)
const struct fsdata_file *f;
if ((file == NULL) || (name == NULL)) {
return ERR_ARG;
I did not understand the error exactly
You will find attached the capture of the error and the programm
Jessy J
Posted on May 28, 2018 at 10:40
The original post was too long to process during our migration. Please click on the provided URL to read the original post. https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I6uH&d=%2Fa%2F0X0000000bxl%2FXHCgLp.pMwYu9pyFfIGdwnOCqaeGoVkihwQdFeletd0&asPdf=false
Posted on May 28, 2018 at 10:25
If you read the LwIP documentation, you will find that you have to write your own custom fs_open to do what you want to do
Pavel A.
Posted on May 28, 2018 at 13:37
else if((strncmp(buf, 'GET /STM32F4xx.html', 19) == 0)||(strncmp(buf, 'GET / ', 6) == 0))
/* Load STM32F4x7 page */
file = fs_open('/STM32F4xx.html');
netconn_write(conn, (const unsigned char*)(file->data), (size_t)file->len, NETCONN_NOCOPY);
fs_close(file);
else
/* Load Error page */
file = fs_open(&file,'/404.html');
fs_close(file);
Indeed in this htppd.c usage of fs_open is inconsistent.
If this code comes from some 'static'  template, need to fix it.
Or, get updated sources from the home site of LwIP project.
-- pa
Jessy J
Posted on May 28, 2018 at 13:59
Yes I corrected it like this
struct netbuf *inbuf;
err_t recv_err;
char* buf;
u16_t buflen;
struct fs_file * file;
/* Check if request to get ST.gif */
if (strncmp((char const *)buf,'GET /STM32F4xx_files/ST.gif',27)==0)
recv_err = fs_open(file,'/STM32F4xx_files/ST.gif');
fs_close(file);
 But i get a warning sayin ' file may be used unitialized in this function .wht does this mean ?? it is declared u nthe begining of the function
Thank you for help
Jessy J
Posted on May 28, 2018 at 14:45
I got error sayin Passing argument 1 of 'fs_open' from incompatible pointer type
Jessy J
Posted on May 28, 2018 at 14:46
and info saying '' expected 'struct fs_file*' but argument is of type 'struct fs_file**'
what does this mean please ?
Jessy J
Posted on May 28, 2018 at 15:01
 so what I wrote is correct ?
struct fs_file *file;
recv_err = fs_open ( fichier, '/ STM32F4xx_files / ST.gif');
but I have the same warning sayin file may be used uninitialized in this function
Like
Show 0 Likes
https://community.st.com/0D70X000006SwhsSAC
Jessy J
Posted on May 28, 2018 at 15:47
I meant file and not fichier
is it correct ?? how can I correct it please !!?
