GreenGuy
Senior III
March 23, 2018
How does the disk_write function in diskio.c work
  • March 23, 2018
  • 1 reply
  • 633 views
Posted on March 23, 2018 at 01:13
As I am debugging code I ran into a problem in f_close which leads me to the disk_write function in diskio.c.  It looks like this function calls itself?  I am stuggling to understand just what this line does:
res = disk.drv[pdrv]->disk_write(disk.lun[pdrv], buff, sector, count);
    1 reply
    Tesla DeLorean
    Guru
    March 23, 2018
    Posted on March 23, 2018 at 01:25
    Calling a function pointer in a structure, allows for multiple drives, multiple interfaces
    This from sd_diskio.h, your wrapper would call SD_write()
    const Diskio_drvTypeDef  SD_Driver =
      SD_initialize,
      SD_status,
      SD_read,
    #if  _USE_WRITE == 1
      SD_write,
    #endif /* _USE_WRITE == 1 */
    #if  _USE_IOCTL == 1
      SD_ioctl,
    #endif /* _USE_IOCTL == 1 */
