KKIM.6
November 1, 2022
How can I program the microcontroller for multi-thread?
  • November 1, 2022
  • 5 replies
  • 2570 views
I want to disassemble the ADC function and BLE data transmission asynchronously.
So, I want to program the microcontroller using multi-thread.
When I coded BLE, It look already used multi-thread but I couldn't understand it exactly.
Is there any example of this?
    Best answer by Ronan GABOU
    There is a MOOC for FreeRTOS on ST Youtube : https://www.youtube.com/playlist?list=PLnMKNibPkDnExrAsDpjjF1PsvtoAIBquX
    iSaeed62
    Hi @KKIM.6​
    Firstly, You need to implement an RTOS, then, for example, you can add your threads in the main.c file. Inside each thread, you can call a function. Each function should have a while(1) loop inside.
    Ronan GABOU
    You can use STM32CubeMX and select RTOS.
    For example for STM32 L4 you can select FreeRTOS and then you can add tasks thanks to CubeMX GUI and generate the project.
    KKIM.6
    KKIM.6Author
    November 2, 2022
    Is there any official Youtube video to follow?
    Ronan GABOU
    Ronan GABOUBest answer
    KKIM.6
    KKIM.6Author
    November 10, 2022
    Thanks for your reply. I'll check the videos!
