Hi all, is there a way to dump a make file from STM32CubeMX?
scott h
Posted on December 16, 2017 at 21:43
I found this link but I can't figure out how to do it:
https://community.st.com/external-link.jspa?url=https%3A%2F%2Fhackaday.com%2F2017%2F07%2F15%2Fstm32cubemx-makes-makefiles%2F
I'm running on Windows but I'd like to create a make file to run Linux.
thank you.
Posted on December 17, 2017 at 13:21
Have you read the manual?
http://www.st.com/content/ccc/resource/technical/document/user_manual/10/c5/1a/43/3a/70/43/7d/DM001047pdf/files/DM001047pdf/jcr:content/translations/en.DM001047pdf
CubeMX is not an IDE, it is a project configuartor and generator. This is just the software.
You have to download packages for the specfic MCU family.
http://scaluza.com/wp-content/uploads/2017/03/cubeMX_update_screen.jpg
http://scaluza.com/stm32f4/intro-in-stm32f4cubemx/
8 REPLIES 8
Mark Peter Vargha
Posted on December 17, 2017 at 05:04
  1. CubeMX is also available on Linux. Have you tried it?
  2. There is a Makefile option in Project / Settings... dialog's Toolchain / IDE drop-down menu. The generated Makefile should be identical on all platforms. Have you tried the compilation?
Posted on December 17, 2017 at 12:51
I don't see a
All I see is Project...new uVision, etc I guess I'm probably running the wrong IDE.
I have downloaded en.ste32cubemx.zip and I can run the examples in KEIL/uVision.
Is there something else I have to do?
thank you!
Posted on December 17, 2017 at 13:06
That is in uVision IDE.
CubeMX is a standalone project generator software.
Check it here:
http://www.st.com/en/development-tools/stm32cubemx.html
Posted on December 17, 2017 at 13:13
I have now downloaded something called STM32CubeMX, looks like an IDE. But I also have a zip file called STM32Cube_FW_L4. I also have an IDE called ARM uVision.
In STM32Cube_FW_L4, there are folders for EWARM, MDK_ARM, SW4STM32, and TrueSTUDIO. If I go into MDK_ARM and double-click on a project it will open the project in ARM uVision.
How do I bring an project into CubeMX?
thank you.
Posted on December 17, 2017 at 13:17
Sorry, I didn't see your reply. I have CubeMX instlalled. Can you tell me how to bring a project in so I can output a make file?
thank you.
Posted on December 17, 2017 at 13:28
You couldn't. CubeMX is for project configuration and creation.
Please describe precisely what do you want to achieve.
Or should we guessing? Maybe you want to generate a Makefile from a uVision project? This is not a tool for that.
Posted on December 17, 2017 at 13:31
Oh, I see. It looks like this is more for creating a project from scratch. Isn't it easier to start with example code?
Anyway, it looks like I asked the wrong question (typical). I think I need to go to the ARM forum and ask:
'Is there a way to generate a make file from ARM  MDK'?
I'm trying to generate a make file for one of the example projects.
thank you.
