Help needed, Flashing a FYSETC S6 V2.1 Error: Activating device: KO. Please, verify the boot mode configuration and check the serial port configuration. Reset your device then try again...
Pilleway
I'm looking for help, because I can not flash the FYSETC S6 V2.1, when trying to do so I get the error mesage.
Technically very limited with Arduino, SMT32cubeprogrammer and FYSETC . My project is a OnStep telescope mount modification to remove DC motors for stepper motors. but need to flash board so I can table test the kit before installation.
All comments and help will be appreciated.
Need easy to follow instructions or recomendation to be able to follow.
Regards and thanks in advance.
Miguel.
Not a board that gets any coverage here.
What instructions are you attempting to follow?
Pilleway
Thanks for your response and taking time to look in to it.
TOnStep instrucctions "For the STM32F446 FYSETC S6:" on https://onstep.groups.io/g/main/wiki/3915
Miguel.
