HAL I2C Communication Problem
Sandeep Dhokne
Posted on July 14, 2017 at 11:52
Dear Sir/Madam,
I am working on STM32F405 mcu.
I developed my code on cubemx and HAL drivers.
I want to interface microchip adc 'MCP3428' via HAL I2C drivers but unfortunately i was failed.
Anybody of you please help me to resolved this issue.
Thank you.
john doe
Lead
Posted on July 14, 2017 at 19:45
        status = HAL_I2C_Mem_Write(&hi2c1,                        // i2c handle
                              (uint16_t)(dev_addr<<1),        // i2c address, left aligned
                              (uint8_t)reg_addr,            // register address
                              I2C_MEMADD_SIZE_8BIT,            //  8bit register addresses
                              (uint8_t*)(&reg_data),        // write returned data to variable named reg_data
                              cnt,                            // write how many bytes
                              100);                            // timeout
you'll have to read your data sheet for addresses and sizes, but the above code is how to read a register
john doe
Lead
                              100);                            // timeout
Posted on July 17, 2017 at 11:39
Thank you so much.
My problem is solved.
