2023-04-13 5:35 AM
When reading from the sd card is completed, HAL_SD_RxCpltCallback is executed. But when I use the HAL_Delay() function within the callback, the rest of the code within the callback after that delay doesn't run.
Any information about this issue is greatly appreciated.
2023-04-14 1:16 PM
Thank you all so much for your answers! You've helped tremendously!
