2015-08-26 1:30 PM
Hello All,
I haven't found any linker script for ld / STM32F411 in the Cube package. Can you advice me on which script to use ? I found old versions on the Internet generally not compatible (libopencm3 for instance) with the ST provided startup script. Any advice / clue will be appreciated. Thanks a lot Zirco2015-08-26 3:13 PM
create a project with CubeMx for Toolchain SW4STM32,
it generates a linker scrip in the folder <CubeProject>/SW4STM32/template Configuration2015-08-27 2:11 AM
Hi Zirconium,
There are ld scripts for STM32F411RE under- STM32Cube_FW_F4_V1.7.0\Projects\STM32F411RE-Nucleo\Templates\TrueSTUDIO\STM32F4xx-Nucleo or- STM32Cube_FW_F4_V1.7.0\Projects\STM32F411RE-Nucleo\Templates\SW4STM32\STM32F4xx-Nucleo besides to the ones under projects folders.-Mayla-To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
2015-08-27 8:43 AM
Mayla, Thomas.004, thank you very much.
ZircoWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
