2018-09-25 01:59 AM
I try to flash using st-link v2 but it show the error message. In my design I cant able to access the Boot 0 and Boot1 pins so no possibility to go for DFU mode.Please give any solution to flash using st-linkV2
kmani@kmani:~$ st-flash erase
2018-09-25T14:18:48 INFO src/stlink-usb.c: -- exit_dfu_mode
2018-09-25T14:18:48 INFO src/stlink-common.c: Loading device parameters....
2018-09-25T14:18:48 WARN src/stlink-common.c: unknown chip id! 0
Mass erasing
2018-09-25T14:19:11 INFO src/stlink-common.c: Loading device parameters....
2018-09-25T14:19:11 WARN src/stlink-common.c: unknown chip id! 0
Mass erasing
2018-09-25 08:01 PM
2018-09-25 08:03 PM
2018-09-25 08:43 PM
If you have connection issues with BOOT0=HIGH, you should look for board level issues.
>>How should I isolate the offending code and stop it?
I find inspection and bisection to be useful methods.
2018-09-25 08:53 PM
Actually that is working board now only it shows error like this ,I will try to give High on Boot0 pin. Thank you sir for your suggestion.
