Flash ReadOut Protection Problem
jki79ros81
Posted on November 07, 2008 at 02:49
15 REPLIES 15
jki79ros81
Posted on May 17, 2011 at 12:49
I want my code in Flash to be protect from downloading by anybody.
I useed FLASH_ReadOutProtection(ENABLE),but this function no acted.
FLASH_ReadOutProtection(ENABLE);
if(FLASH_GetReadOutProtectionStatus() == SET){
else{
What is the problem?
heavelove1
I think you should reset the mcu, let the mcu load new read protech option to OBR.RDP
jki79ros81
Thank you heavelove!
I had so,but it is the same.
FLASH_ReadOutProtection(ENABLE) ;
why not reach to this point ?
else{
Please advice me!
jilisegiar
did you use the following function to reset the CPU:
NVIC_GenerateSystemReset();
for more details, see the \FWLib\examples\FLASH\Write_Protection example
STM32F10xFWLib:
http://www.st.com/mcu/modules.php?name=mcu&file=familiesdocs&FAM=110#Firmware
heavelove1
Maybe check status first is better:
//...reach this point is ok.
else{
__delay_cycles(100000);
jki79ros81
I had so,but it is too the same.
When I debug,always it reach in the same as follwing.
else{
//. Here is breakpoint.
//. Always reach in this point. Why?
for(i = 0; i< 50000; i++){};
Please help me.
heavelove1
I've tested on these code, and it worked ok:
Led_Config();
Led1_ON();Led2_OFF();Led3_OFF();Led4_OFF();
else
FLASH_Unlock();//This MUST done first
Led1_ON();Led2_ON();Led3_ON();Led4_ON();
Good luck to you!
jki79ros81
Dear heavelove,a person from the same province.
Thank you very much.
It's OK.
But,Ah,unfortunately,I am hurried into an error.
I protect my flash and run erase flash. So I can't flash download. I use STM32F103RD,Keil.
I can use it after?
Please help me.
[ This message was edited by: jki79ros81 on 03-11-2008 02:56 ]
heavelove1
You can erase the chip use ISP.
A chinese version ISP program can download from www.mcuisp.com
