Flash Keys - How to change?
damh
Posted on March 11, 2010 at 14:16
10 REPLIES 10
damh
Posted on May 17, 2011 at 13:42
Ok, i will test it.
If it is, like you have decribed, ROP perhaps only works with enabled debug access?
I suppose, that intruding code won't check ROP ;)
So I have to get JTAG or SWD access, copy montitor programm to RAM, set BOOT pins to boot from RAM, disconnect debugger, reset and ...
my programm will have full access to the system?
This sounds not very secure, but would fit to the rest like datasheet quality ;)
