2012-05-13 1:33 PM
did a google search none of the links worked.
I installed st-link_v2_usbdriver.zip, ST-LINK_Utility_V2.2Patchv10.zip I searched my computer for STLinkUSBDriver.dll and could not find it. I was able to install the STLink dongle that shows up in my device list.2012-05-13 11:48 PM
In general, I'm aware of two problems that might cause your trouble.
One is a 32 Bit / 64 Bit driver issue. The other, more probable, is ''Addon'' software that some PC/Notebook distributors install. If your host is a notebook, and has lots of preinstalled software, try to deinstall suspicious stuff. If you want to dig in, I could recommend the ProcessExplorer and DependencyWalker.2012-05-14 7:15 AM
it is a 32 bit Net book with only 50% real memory allocated.
Win7 starter. I have drivers for Ardrino, Maple installed and working. when I plug in the STM32F4 Discovery I see the ST Link as a hub. the directory STMicroelectronics\st_toolset was added but no files. I did a file search and did not find the fileSTLinkUSBDriver.dll
anywhere on the system. is there a place I can get the STLinkUSBDriver.dll ?2012-05-14 8:18 AM
As far as i know, it usually comes with tool suites that support the stm32f4.
Atollic and Keil MDK have their versions copied somewhere intheir folder subtree. Crossworks wants you to set a link to an existing DLL, at least under Windows. The linux version supports stlink V2 out of the box. If the STLink utility does not come with this DLL, I could only suggest download and install one of the tools mentioned above (and not forgetting IAR...).2012-05-14 8:21 AM
found it as an attachment to
''https://my.st.com/public/STe2ecommunities/mcu/Lists/STM32VLDiscovery/flat.aspx?RootFolder=%2Fpublic%2FSTe2ecommunities%2Fmcu%2FLists%2FSTM32VLDiscovery%2FProblem%20with%20Keil%20uVision%204%20Failure%20loading%20STLinkUSBDriver.dll%209974&FolderCTID=0x01200200770978C69A1141439FE559EB459D758000491D59B8574F8049B5DFA3E8B21CBA51¤tviews=4981''2012-05-14 8:25 AM
2012-05-14 8:42 AM
found the source to STLink
https://github.com/texane/stlink2012-05-14 9:36 AM
> https://github.com/texane/stlink This is a port to linux, which is a different story...2012-05-14 10:12 AM
