Failed to load flash loader: C:\Program Files\IAR Systems\Embedded Workbench 8.2\arm\config\flashloader\ST\FlashSTM32F401xE.flash
2018-08-28 9:45 PM
Hi.
Here I am on a task of Migrating a code which is working the STM32F411RE processor to STM32L476RG. I have done the all the steps as per the guidelines given by the ST.
I am facing an error, " Failed to load flash loader: C:\Program Files\IAR Systems\Embedded Workbench 8.2\arm\config\flashloader\ST\FlashSTM32F401xE.flash".
After migrating code to STML476RG, the flash loader must be changed to STM32L476RG.flash.
I am not getting any idea how to change the flash loader to STM32L476RG.flash.
Please help me.
2018-08-29 1:48 AM
I recommend you to use the STM32CubeProgrammer software tool for device-programming and firmware upgrade for STM32 microcontrollers, following the instruction in the User Manual and System requirements.
- Link:
Best Regards
Imen
Imen
