error: array type has incomplete element type
‎2018-03-29 10:29 PM
This is occurring in fsdata_custom.c in the LwIP_HTTP_Server_Netconn_RTOS project I imported from CubeMX. The struct that is being referenced is :
struct fsdata_file {
const struct fsdata_file *next; const unsigned char *name; const unsigned char *data; int len; u8_t flags;#if HTTPD_PRECALCULATED_CHECKSUM u16_t chksum_count; const struct fsdata_chksum *chksum;#endif /* HTTPD_PRECALCULATED_CHECKSUM */};and the HTTPD_PRECALCULATED_CHECKSUM is defined as 0.
Where the error is occurring in fsdata_custom.c is at: (line 2336
const struct fsdata_file file__STM32F7xx_files_logo_jpg[] = { {
file_NULL,data__STM32F7xx_files_logo_jpg,data__STM32F7xx_files_logo_jpg + 28,sizeof(data__STM32F7xx_files_logo_jpg) - 28,1,}};According to the struct definition it looks like all the elements are there so I am confused.
Anyone run across this?
‎2018-06-27 10:00 PM
In case anyone else comes across this - fsdata_custom.c isn't meant to be directly compiled, it gets included in httpd/fs.c. I removed fsdata_custom.c from my Makefile and the errors went away
‎2018-06-27 11:31 AM
hey greg - did you ever find a solution to this? I'm having the same problem and can't seem to figure it out
‎2018-06-28 12:07 PM
Ben, sorry for the late reply. Yes you got it right. For me I simply excluded the file from the build in the IDE.
‎2018-10-25 8:04 AM
Hello Guys,
I'm having the same problem when trying to build the example; my problem don't go away when I exclude that file from the build, I mean is replaced by a ..\Middlewares\Third_Party\LwIP\src\apps\httpd\fs.c:41:27: fatal error: fsdata_custom.c: No such file or directory
#[include "fsdata_custom.c"]​
Don't know if you would have any ideas
‎2020-03-24 11:57 AM
I was able to get rid of the errors by including the fsdata.h file. But eventually just excluded fsdata_custom.c. I then ended up with 3 more fatal errors
multiple definition of _isatty
(2)Undefined reference to "missing_USE_FREERTOS_macro"
It must be nearly IMPOSSIBLE for St to create examples that actually build and work as I have yet to see one.
Adding "USE_FREERTOS" to the Project Properties solved one. But still have no solution for _isatty. Searching for it.. doesn't show up anywhere.
