2021-04-08 9:46 PM
en.x-cube-dspdemo\X-CUBE-DSPDEMO\Projects\STM32F429I-Discovery\STM32F429_DSPDEMO\MDK-ARM When Open and compile error come like below its fresh copy no modification done .how can i resolve that ?
compiling BasicMathFunctions.c...
..\..\..\..\Drivers\CMSIS\Include\core_cm4.h(129): error: #35: #error directive: "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)"
#error "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)"
e:\Users\MY PC\AppData\Local\Arm\Packs\ARM\CMSIS\5.7.0\CMSIS\DSP\Source\BasicMathFunctions\BasicMathFunctions.c: 0 warnings, 1 error
compiling BayesFunctions.c...
e:\Users\MY PC\AppData\Local\Arm\Packs\ARM\CMSIS\5.7.0\CMSIS\DSP\Source\BayesFunctions\BayesFunctions.c: 0 warnings, 1 error
compiling CommonTables.c...
e:\Users\MY PC\AppData\Local\Arm\Packs\ARM\CMSIS\5.7.0\CMSIS\DSP\Source\CommonTables\CommonTables.c: 0 warnings, 1 error
compiling ComplexMathFunctions.c...
e:\Users\MY PC\AppData\Local\Arm\Packs\ARM\CMSIS\5.7.0\CMSIS\DSP\Source\ComplexMathFunctions\ComplexMathFunctions.c: 0 warnings, 1 error
compiling DistanceFunctions.c...
e:\Users\MY PC\AppData\Local\Arm\Packs\ARM\CMSIS\5.7.0\CMSIS\DSP\Source\DistanceFunctions\DistanceFunctions.c: 0 warnings, 1 error
compiling ControllerFunctions.c...
e:\Users\MY PC\AppData\Local\Arm\Packs\ARM\CMSIS\5.7.0\CMSIS\DSP\Source\ControllerFunctions\ControllerFunctions.c: 0 warnings, 1 error
compiling FastMathFunctions.c...
e:\Users\MY PC\AppData\Local\Arm\Packs\ARM\CMSIS\5.7.0\CMSIS\DSP\Source\FastMathFunctions\FastMathFunctions.c: 0 warnings, 1 error
compiling FilteringFunctions.c...
e:\Users\MY PC\AppData\Local\Arm\Packs\ARM\CMSIS\5.7.0\CMSIS\DSP\Source\FilteringFunctions\FilteringFunctions.c: 0 warnings, 1 error
compiling stm32f4xx_hal_dac_ex.c...
compiling MatrixFunctions.c...
e:\Users\MY PC\AppData\Local\Arm\Packs\ARM\CMSIS\5.7.0\CMSIS\DSP\Source\MatrixFunctions\MatrixFunctions.c: 0 warnings, 1 error
compiling SVMFunctions.c...
e:\Users\MY PC\AppData\Local\Arm\Packs\ARM\CMSIS\5.7.0\CMSIS\DSP\Source\SVMFunctions\SVMFunctions.c: 0 warnings, 1 error
compiling StatisticsFunctions.c...
e:\Users\MY PC\AppData\Local\Arm\Packs\ARM\CMSIS\5.7.0\CMSIS\DSP\Source\StatisticsFunctions\StatisticsFunctions.c: 0 warnings, 1 error
compiling SupportFunctions.c...
e:\Users\MY PC\AppData\Local\Arm\Packs\ARM\CMSIS\5.7.0\CMSIS\DSP\Source\SupportFunctions\SupportFunctions.c: 0 warnings, 1 error
compiling TransformFunctions.c...
e:\Users\MY PC\AppData\Local\Arm\Packs\ARM\CMSIS\5.7.0\CMSIS\DSP\Source\TransformFunctions\TransformFunctions.c: 0 warnings, 1 error
compiling stm32f4xx_hal_dma_ex.c...
compiling system_stm32f4xx.c...
compiling LCDConf_stm32f429i_disco_MB1075.c...
".\STM32F429I_DISCO_DSP\X-CUBE-DSPDEMO.axf" - 13 Error(s), 0 Warning(s).
Target not created.
Build Time Elapsed: 00:00:35
2021-04-15 4:01 AM
Hi @senthil ,
I am using the same example and I am able to compile it without issue using Keil.
I suggest you to make sure that:
-Amel
2021-04-15 4:01 AM
Hi @senthil ,
-Amel
