ECDSAsign
2018-03-22 4:44 AM
Hi all,
I am currently on a project which leverage the x-cube-cryptolib to send messages cross the network securely. To be specific, I want to use the ECDSA part to sign and verify my messages.
After some exploration and experiments, I can run through the ECC example. However, the example used a generated private/public keys (by the lib) which are structured well in memory. I wanted to use my personal private key for sign and my personal public key for verify.
So here are the questions -
1. How can I covert a private key (in pem or hex format) to an ECCprivKey_stt structre?
2. How can I convert a public key (in pem or hex format) to a ECpoint_stt structure?
3. How can I convert a signature in hex format to a ECDSAsignature_stt structure?
Any suggestions on these? are there any apis that cover these parts ? If I want to implement them, s
hould I deal with the little/big endian issues if the private/public keys come from my MacBook?Thank you so much!
2018-03-25 7:51 PM
I figured it out by experimenting with openssl. Apparently we don't need to handle the big/small endian in user code. Given a private key, it worked to sign a message from STM32 with the specified key, send the signature to network and verify it from a laptop.
