2008-12-16 4:43 AM
double buffer
2011-05-17 3:56 AM
hi i want to ask about using double buffer instead of simple buffer ,using the example of usb mass storage found on the site, i changed the intialization of the endpoint in usb_prop.h,what should i do other than this??also are there any limitations on the addresses i chose for the buffers?
