Discovery-WiFi and /ALRT signal
hbarta2
Posted on February 10, 2015 at 13:36
The Murata manual describes the /ALRT signal that the Murata chip uses to indicate to the host that it has a message to send. Is this signal available on the Discovery-WiFi board? Can it be made available if not by default (and by default, I mean using the SPI firmware available from Murata.)
The Murata SyChip SNIC monitor has the capability to assign the ALRT signal to values from 0-19 but I do not know how these map to pins on the Discovery-WiFi board.
#discovery-wifi-alrt
0 REPLIES 0
