Cube pinouts for STM32F407VETx needs review
EugeneP
Posted on May 21, 2015 at 01:14
It seems power pin on the generated pin assignments (especially pin 19 - 22) needs to be verified.
Pin 21 should be VREF+ instead of VDDA?
chrif
Posted on June 01, 2015 at 12:01
I checked Pin 21 for STM32F407VETx with STMcubeMx 4.8 and I found the error also. In datasheet Pin 21 corresponds to VREF but in the generated pinouts description pin 21 is VDDA. The same error exist for STM32F417VETx.
stm32cube-t
Posted on June 04, 2015 at 18:06
Thank you for reporting this issue. It will be solved in MX 4.9 release.
