Conversion of decimal to string
Mohan1
Hello, I am getting data in decimal format and to need to convert it into string.So how can i do it?
The math/logic here are pretty simple, sort of thing given as a homework assignment to check if you have some grasp of topic.
Tip:do it backward, generating the least significant digits first.
Library also has things like itoa() which is more lightweight than sprintf() and variants.
http://www.cplusplus.com/reference/cstdlib/itoa/
Ozone
Principal III
sprintf() would be the simplest way.
Thank you so much sir.I used itoa function and it shows correct decimal value in docklight that i required.Thank you once again sir.
