Bus sharing
GauravK
-Hi, wanted to know, how to go about having a parallel bus shared by microcontroller and fpga.
-fpga and microcontroller both r/w from external sram over the same bus.
1. What should be the configs for microcontroller : fsmc in memory to memory with DMA2 burst?
2. Will fpga and microcontroller both be masters in the bus. how can writing only 1 device is handled?
please check
The MCU isn't going to share or arbitrate the bus.
Put whatever logic you need to manage things in the FPGA
4 REPLIES 4
GauravK
I'm reading about fsmc, parallelly wanted to know about the implementation from experts.
Also the idea is to directly pass sram data to lcd (on a different interface) rather than having whole data in internal memory.
GauravK
Thanks. Does arbitration in FPGA double the I/O's requirement for parallel bus?
Please can I know any reference diagram
GauravK
Closing this thread.... Will try soon and come up with queries soon...
