Baud Rate problem
Options
‎2015-07-09 8:15 AM
Posted on July 09, 2015 at 17:15
The original post was too long to process during our migration. Please click on the attachment to read the original post.
4 REPLIES 4
Options
‎2015-07-09 10:14 AM
Posted on July 09, 2015 at 19:14
Can someone help me please?
Why can't you use the standard code within SystemInit() and system_stm32f4xx.c to set up the clocks and PLL properly?Make sure it's using the HSE clock, and that it's clocking properly at 8 MHz. You're using the STM32F4-DISCO right? Or something else?Output the HSE and PLL clocks using the PA8 (MCO) pin, and measure them with a scope.If you're not using an 8 MHz HSE, then make sure the HSE_VALUE define reflects the actual clock rate you're using.
Options
‎2015-07-10 7:04 AM
Posted on July 10, 2015 at 16:04 Thank you for reply. Yes, I'm using stm32f4 discovery. Now I'm confused... with the previous code i get the properly clock at the timers. I read PA6 in a scope and i got exactly 40 kHz. Now I configured clock and PLL in SystemInit() and system_stm32f4xx.c as you said. I configured HSE_VALUE at 8MHz, PLL_M 5, PLL_N 210, PLL_P 2, AHB prescaler 1, APB1 prescaler 4 and APB2 prescaler 2. I should get CPU at 168 MHz, APB2 at 84 and APB1 at 42. But now the timers doesn't clock properly!! Now I read in PA6 7,58 kHz frequency instead of 40 kHz. What's going on?
Options
‎2015-07-10 7:40 AM
Posted on July 10, 2015 at 16:40
What's going on?
Ultimately I think you're best placed to figure that out.RCC_ClocksTypeDef RCC_Clocks;
RCC_GetClocksFreq(&RCC_Clocks);
printf(''SYS:%d H:%d, P1:%d, P2:%d
RCC_Clocks.SYSCLK_Frequency,
RCC_Clocks.HCLK_Frequency, // AHB
RCC_Clocks.PCLK1_Frequency, // APB1
RCC_Clocks.PCLK2_Frequency); // APB2
You could use the APB clocks, as the system deciphers it's internal configurations, instead of using SystemCoreClock.
Options
‎2015-07-10 8:18 AM
Posted on July 10, 2015 at 17:18
Output:
168000000 168000000 42000000 84000000 I don't know really what happened but now the timers work and I get from USART the correct data. Thank you very much
