Avoid checking BOOT0, possible?
andy2
Posted on May 26, 2015 at 17:01
I made a mistake of not putting BOOT0 pin connect to ground, which the STM32L051 MCU is not working at the moment.  Is it possible to rewrite the bootloader to I could avoid checking the BOOT0 pin for development purpose only?  The deadline would be too close for me to make another set of board.
If rewriting the bootloader is a method to go, any pointer to where to find the info?
Thanks.
Posted on May 26, 2015 at 19:10
No.
Lift the pin, use a jumper wire, or drill out the pin, etc. Whatever remediation techniques you have to address the connectivity issue.
andy2
Posted on June 03, 2015 at 05:00
Sorry to reply late.  Yes, made another board, and it is all working now.
Thanks!
