assert function in littlefs file system using for write file in w25q20 flash IC
shiv7505
Hey everyone, I am using w25q20 external flash for writing data so I have to use the file system, I am facing an issue I am not able to open the file and write data in it, Can anyone suggest any solution to it, is very helpful.
I dropped the link to code https://drive.google.com/open?id=1FvxeFff5Wv4JAjTCuwM0TM6oIppG9jD3&usp=drive_fs
Thank you.
0 REPLIES 0
