ARM based microcontroles intrerrupt implementation
sakowski
Posted on May 10, 2015 at 01:05
I have a question regarding good practices.
Shall we code interrupt handling like that
http://wklej.to/k4oVO
 or shall we code interrupt handling like that
http://wklej.to/f1TTq
Best Regards
#stm32
Posted on May 10, 2015 at 03:31
A)
Always assume that more that one source can be signalling upon entry, if you fail to clear all the sources the routine will tail-chain back into itself. In the worse case scenario it will never leave the interrupt cycle. This usually occurs if you enable an interrupt source that you don't have service code for.
