AN2606 (internal bootloader) documentation errors
‎2016-08-09 10:19 AM
These are minor errors, but it'd a pity to have them nevertheless, once spotted.
- Table 1. Applicable products - missing part numbers altogether for L1, F1 and F2
- Table 3. Embedded bootloaders - for F0, in Device column, ''STM32F030xx4/6'' with Bootloader ID should presumably read STM32F03xx4/6
‎2016-08-10 12:47 AM
‎2016-08-11 3:51 AM
Hi JW,
Thanks for highlighting the issue, it is reported internally and will be corrected soon.-Syrine-- Mark as New
‎2016-10-17 3:27 AM
Hi wolff.roger,
Can you please clarify your comments about the F042 device on AN2606 Doc?What's wrong with it ?
Regards,-Heisenberg-- Mark as New
‎2016-10-17 7:58 AM
He discussed it in previous threads, but my recollection is that the loader blind writes to a register blowing away the current setting, and adjusting the clock, rather than using the factory trim factor.
I'd dig into the forum, but the software doesn't let me view someones threads/posts via their avatar/homepage like every other platform.Up vote any posts that you find helpful, it shows what's working..
‎2016-10-17 8:29 AM
