2016-01-21 10:41 AM
Hello everybody!
I'm trying to read two ADC channels in STM32F042 microcontroller with DMA without interruption. I expected the DMA reads channel 0 then channel 1 filling five samples of each channel in my vector. But the vector I created only updates the first value. The complete projectare attached. Does anyone know of anything that can help?/* Includes ------------------------------------------------------------------*/
#include ''stm32f0xx_hal.h''
/* USER CODE END Includes */
ADC_HandleTypeDef hadc;
DMA_HandleTypeDef hdma_adc;
UART_HandleTypeDef huart2;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
static void MX_DMA_Init(void);
static void MX_ADC_Init(void);
static void MX_USART2_UART_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
uint32_t adcBuffer[20];
uint32_t *pADC = &adcBuffer[0];
void readAdc(void) {
HAL_ADC_Stop_DMA(&hadc);
memset(pADC, 0, strlen(pADC));
HAL_ADC_Start_DMA(&hadc, pADC, 10);
/* USER CODE END 0 */
int main(void)
/* USER CODE BEGIN 1 */
char str[10];
char *separator = ''**********************\r\n'';
/* USER CODE END 1 */
HAL_Init();
SystemClock_Config();
MX_GPIO_Init();
MX_DMA_Init();
MX_ADC_Init();
MX_USART2_UART_Init();
/* USER CODE BEGIN 2 */
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
readAdc();
HAL_Delay(10);
for(int i = 0; i<10; i++) {
sprintf(str, ''%10d\r\n'', adcBuffer[i]);
HAL_UART_Transmit(&huart2, str, strlen(str), 100);
HAL_Delay(30);
HAL_GPIO_TogglePin(LED_STS_GPIO_Port, LED_STS_Pin);
HAL_UART_Transmit(&huart2, ''**********-**********\r\n'', strlen(''**********-**********\r\n''), 100);
HAL_Delay(1000);
/* USER CODE END 3 */
/** System Clock Configuration
void SystemClock_Config(void)
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI|RCC_OSCILLATORTYPE_HSI14;
RCC_OscInitStruct.HSI14State = RCC_HSI14_ON;
RCC_OscInitStruct.HSICalibrationValue = 16;
RCC_OscInitStruct.HSI14CalibrationValue = 16;
HAL_RCC_OscConfig(&RCC_OscInitStruct);
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_SYSCLK;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0);
/* ADC init function */
ADC_ChannelConfTypeDef sConfig;
/**Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
hadc.Instance = ADC1;
hadc.Init.ClockPrescaler = ADC_CLOCK_ASYNC;
hadc.Init.Resolution = ADC_RESOLUTION12b;
hadc.Init.DataAlign = ADC_DATAALIGN_RIGHT;
hadc.Init.ScanConvMode = ADC_SCAN_DIRECTION_FORWARD;
hadc.Init.EOCSelection = EOC_SEQ_CONV;
hadc.Init.LowPowerAutoWait = DISABLE;
hadc.Init.LowPowerAutoPowerOff = DISABLE;
hadc.Init.ContinuousConvMode = DISABLE;
hadc.Init.DiscontinuousConvMode = DISABLE;
hadc.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
hadc.Init.DMAContinuousRequests = DISABLE;
hadc.Init.Overrun = OVR_DATA_PRESERVED;
HAL_ADC_Init(&hadc);
/**Configure for the selected ADC regular channel to be converted.
sConfig.Channel = ADC_CHANNEL_1;
sConfig.Rank = ADC_RANK_CHANNEL_NUMBER;
sConfig.SamplingTime = ADC_SAMPLETIME_1CYCLE_5;
HAL_ADC_ConfigChannel(&hadc, &sConfig);
/* USART2 init function */
huart2.Instance = USART2;
huart2.Init.BaudRate = 115200;
huart2.Init.WordLength = UART_WORDLENGTH_8B;
huart2.Init.OneBitSampling = UART_ONEBIT_SAMPLING_DISABLED ;
huart2.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
HAL_UART_Init(&huart2);
* Enable DMA controller clock
__DMA1_CLK_ENABLE();
/* DMA interrupt init */
HAL_NVIC_SetPriority(DMA1_Channel1_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(DMA1_Channel1_IRQn);
}2016-01-21 12:28 PM
Hello guys, I solve this problem. Now I can read 2 analog inputs in sequence with DMA. Below can be seen the result. The channel 0 has a resistive divider and channel 1 are tied to ground.
********** - ********** CH0: 2043 CH1: 0 CH0: 2045 CH1: 0 CH0: 2045 CH1: 0 CH0: 2045 CH1: 0 CH0: 2048 CH1: 0 ********** - ********** The change I made was in hadc.Init.ClockPrescaler which by default is ADC_CLOCK_ASYNC and there is no change in STM32CubeMX because the options in dropdown list are blocked. I add the second channel to read on sConfig too, because STM32CubeMX doesn't do this even if the channels are selected on graphical interface of Cube. Here is the code that works for me:/* Includes ------------------------------------------------------------------*/
uint32_t adcBuffer[10];
for(int i=0; i<10; i++) {
adcBuffer[i] = 0x00;
HAL_ADC_Start(&hadc);
int main(void)
char str[10];
HAL_Init();
MX_GPIO_Init();
MX_DMA_Init();
MX_ADC_Init();
HAL_ADCEx_Calibration_Start(&hadc);
/* Infinite loop */
while (1)
readAdc();
HAL_Delay(20);
for(int i = 0; i<10; ) {
sprintf(str, ''CH0: %4d
CH1: %4d
'', adcBuffer[i], adcBuffer[i+1]);
HAL_Delay(30);
i+=2;
''), 100);
HAL_Delay(1000);
hadc.Init.ClockPrescaler = ADC_CLOCKPRESCALER_PCLK_DIV4; // <--- CHANGED MANUALLY BECAUSE STM32CUBEMX OPTIONS FOR CLOCK ARE BLOCKED
hadc.Init.ContinuousConvMode = ENABLE;
sConfig.Channel = ADC_CHANNEL_0;
// <--- ADD THE SECOND CHANNEL TO READ. STM32CUBEMX DOESN'T DO THIS...
/** Configure pins as
* Analog
* Input
* Output
* EVENT_OUT
* EXTI
* Free pins are configured automatically as Analog (this feature is enabled through
* the Code Generation settings)
/* GPIO Ports Clock Enable */
__GPIOB_CLK_ENABLE();
__GPIOF_CLK_ENABLE();
__GPIOA_CLK_ENABLE();
/*Configure GPIO pins : PB8 PB1 */
GPIO_InitStruct.Pin = GPIO_PIN_8|GPIO_PIN_1;
GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
/*Configure GPIO pins : PF0 PF1 */
GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_1;
HAL_GPIO_Init(GPIOF, &GPIO_InitStruct);
/*Configure GPIO pin : LED_STS_Pin */
GPIO_InitStruct.Pin = LED_STS_Pin;
GPIO_InitStruct.Speed = GPIO_SPEED_LOW;
HAL_GPIO_Init(LED_STS_GPIO_Port, &GPIO_InitStruct);
/*Configure GPIO pins : PA5 PA6 PA7 PA9
PA10 */
GPIO_InitStruct.Pin = GPIO_PIN_5|GPIO_PIN_6|GPIO_PIN_7|GPIO_PIN_9
|GPIO_PIN_10;
}2016-03-10 6:35 AM
Hi jeremy_cis,
Have you tried with the last version of STM32CubeMx 4.13.0 ?-Hannibal-2016-03-10 9:32 AM
Yes Hannibal, now I can choose ADC_CLOCKPRESCALER_PCLK_DIV2 or ADC_CLOCKPRESCALER_PCLK_DIV4 in STM32CubeMX and ''sConfig.Channel'' section is configured correctly for the selected channels.
2016-03-10 9:54 AM
Hi jeremy_cis,
That's good. Thank you for your contribution.-Hannibal-2016-03-18 1:02 PM
2016-03-18 1:18 PM
The Rank# enumeration must increment for each channel you add.
2016-03-18 2:00 PM
Be aware that editing posts changes the chronology, see earlier response to your question.
2016-03-29 12:00 PM
Hello, I'm sorry for the delay! We did not get a notification of your question in my email. These problems and ''solutions'' that we applied have been fixed in the new version of STM32CubeMX. Please try STM32CubeMx v4.0 and Firmware Package for Family STM32F0 v1.5.0.
My read function:void readAdcDma(TYPEDEF_ADC_CH channel) {
HAL_ADC_Stop_DMA(&ADC_Handle);
while(HAL_ADC_DeInit(&hadc) != HAL_OK);
for(int i=0; i<ADC_BUFFER_SIZE; i++) {
if(channel == ADC_CH0) {
sConfig.SamplingTime = ADC_SAMPLETIME_71CYCLES_5;
else if(channel == ADC_CH1) {
else if (channel == ADC_CH2) {
sConfig.Channel = ADC_CHANNEL_2;
HAL_ADC_Start_DMA(&ADC_Handle, pADC, ADC_BUFFER_SIZE);
HAL_ADC_Start(&ADC_Handle);
//Wait for DMA copy data...
HAL_Delay(20); //Delay (((1/60Hz)/400)*500) ~= 20ms
}/* ADC init function */
hadc.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV4;
hadc.Init.EOCSelection = EOC_SINGLE_CONV;
sConfig.SamplingTime = ADC_SAMPLETIME_55CYCLES_5;
