2015-02-11 4:03 AM
Hi all,
I need a mcu with 6xUSART or UART.I couldn't find like it.Parametric search s me.Different data between parametric search and datasheet.Can you suggest to me a mcu like it.2015-02-12 7:29 AM
2015-02-12 9:09 AM
Different data between parametric search and datasheet. Can you suggest to me a mcu like it.
The data sheet is the controlling document, enumerate through the pins on whatever form factor you've chosen and confirm if all the U[S]ART Tx and Rx pins exit the part. Would take five minutes. I'm pretty sure ALL the F2/F4 die have 6 asynchronous serial ports which are usable. There may be DMA limitations. There may be system level conflicts on low pin count parts depending on what else you're doing. Look at Cube or Micro Xplorer for automated pin fitting.We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
