X-CUBE-MCSDK 5 software generated code have lot of compile error
GArun
i attached error messages and motor parameter file for referance.
i generated code from motor control workbench X-CUBE-MCSDK 5 for keil MDK-ARM and compile without any touch. i throw lot of errors.
how can i solve this problem?
GArun
problem solved !, after uninstall older version 4.2
GArun
Laurent Ca...
Lead II
The question has been moved from the section "Motor Control Hardware" to the "STM32 Motor Control" section (the question is about the STM32 MC SDK).
Best regards
