2024-05-15 6:59 PM - last edited on 2024-05-16 12:50 AM by Peter BENSCH
Hello I want support for STSPIN32G4 EMI Issue
I took tests for Farfield EMI Report at STSPIN32G4 Standby condition
Report shows QP are over than Limit at 190.547MHz, 253.803MHz
and I also get similar result by using Near-field prove(Proved Noise Peaks : 185.91, 123.94, 247.88, 309.84MHz) this result are same at evspin32g4-dual(also Flash Erase conditions results)
I guess 62 MHz harmonic noise occurs between STM32G431 and STSPIN32G4 Internal Control logic Because I observe noise when Voltage input to VM and REGIN for the (in 3.3V externally supplied circuit)
I want to know how could i solve this problem(Resolving EMI noise)
2024-11-13 12:17 AM
Hello @DKim.39,
This post has been answered through our local support team.
2024-11-13 12:17 AM
Hello @DKim.39,
2024-11-27 1:25 AM
Hello , we found the same problem with EMC. May I know if you have any solution of this radiation problem? Thanks Josef Pazderka
2026-04-21 11:48 PM
Hello GMA,
I have the same problem using STSPIN32G4 and I cannot view the answer.
Could you show the support team answer, please?
Thank you very much
Federico
