??Fil
MotorControl Workbench 5.2.0 does not detect STM32CubeMX
  • September 25, 2018
  • 3 replies
  • 1396 views
Hello all. I tried finding a solution on all the resources I can think of, tried uninstalling/ reinstalling the Cubemx and MotorControl Workbench, following the suggested order (first install cubemx, run it at least once before launching the workbench) to no avail. I cannot generate code sin MotorControl Workbench 5.2.0 does not detect STM32CubeMX version 4.27.0. Your help would be much appreciated.
yxie.9
Visitor II
September 26, 2018
if i change the cubeMX repo path,MotorControl Workbench 5.2.0 will not generate the right code.does you change the repo path
??Fil
??FilAuthor
Hello ly11262255204...
repo path remains default which in my case is : C:/Users/pc/STM32Cube/Repository/
Laurent Ca...
Senior III
June 22, 2021
The question has been moved from the section "Motor Control Hardware" to the "STM32 Motor Control" section (the question is about the STM32 MC SDK).
Best regards
