Motor fluctuates at +80rpm and -80rpm
VGani.1
I used Nucleo-F446RE and X-Nucleo-IHM08M1 for FOC control of PMSM motor.
Motor Profiler to determine parameters.
Then WB, CubeMX and CubeIDE able to generate code.
Start Motor using Monitor screen, the motor fluctuates at +80rpm and -80rpm.
Need help.
Laurent Ca...
Lead II
Dear @Community member​
For more readability, I have shortened the text of the title of your question and I have transferred all of the original text of your question to the description part of the question.
Best regards
Laurent Ca...
Lead II
I just come back from vacation.
Have you any news on your problem?
Best regards
VGani.1
Dear @Laurent Ca...​ ,
I go through the tutorial videos in ST Youtube Channel and use FOC startup settings to run the motor. Its working now.
Thank you for the response.
