Motor control with a resolver, using either STEVAL-ESC001V1 or B-G431B-ESC1 and the MCSDK
MRahi.3
I am working on a motor control project. The position feedback is given by a motor resolver.
The issue is that I cannot find the option for a resolver in the Motor Control Workbench, only Hall sensors or Encoder. Is there any way to go past this restriction for this use case, either through hardware or software ?
Any assistance is much appreciated.
Thank you
0 REPLIES 0
