How to change value of over current in code generated by motor control workbench 5.4?
Ryada.1
Hi
I am running BLDC motor using eval 3202 board and when some load on motor is given it trips and gives indication over current fault in motor control workbench.
So how to change value of over current in code generated by motor control workbench 5.4 ?
5 REPLIES 5
Laurent Ca...
Lead II
Dear @Ryada.1​
According to the forum rules with the "STM32 Motor Control" tag, I edited your post to shorten your title and moved your entire title into the text which is empty.
Best regards
Laurent Ca...
Laurent Ca...
Lead II
Dear @Ryada.1​
Did you try to tune amplification settings in MC workbench (click on "Current setting" and the "Calculate")?
Best regards
Laurent Ca...
Laurent Ca...
Lead II
Dear @Ryada.1​
Any news?
Best regards
Laurent Ca...
Ryada.1
yes gain can change current measured value?
Laurent Ca...
Lead II
Dear @Ryada.1​
For sure, tune amplification settings in MC workbench will changes the current measured values.
Best regards
Laurent Ca...
