Can not export the code in X-CUBE MCSDK 6.1.0
Tobe
Senior III
Everything works fine with my cubeIDE installation.
I have cubeMX 6.8.0 installed...
SRedd.5
Senior III
MCSDK 6.2.0 is the latest version it has bug fixes from 6.1.0, using that is better option.
But does it fix the issue? I cant find any changelog for the new version...
I am not sure if it will fix the issue. But probably re installing with the latest versions of MCSDK and CubeIde and CubeMx (6.10.0) may be useful.
