2026-05-16 1:07 AM - last edited on 2026-05-16 2:04 AM by Andrew Neil
In this file, the line:
USBx_HC((uint32_t)ch_num)->HCSPLT |= USB_OTG_HCSPLT_XACTPOS_Pos;wrongly alters bits 1 to 3 of register HCSPLT
That can be fixed simply by removing this line, since middle payload is encoded by bits 00 in the XACTPOS field.
2026-05-18 1:17 AM
Hi @cs
I assume middle payload must be encoded as 00 as described in register description fields
An internal ticket CDM0062710 is submitted to dedicated team to report this potential bug.
2026-05-16 1:11 PM - edited 2026-05-17 1:14 AM
2026-05-16 11:41 PM
Yes, it's what I think. The coding style here is to set appropriate bits to one in the XACTPOS field, and all XACTPOS bits are zero for middle payload.
2026-05-18 1:17 AM
Hi @cs
