when I am sending data using USB, when the callback in my firmware gives me USB BUSY? i am using STM32F303VC discovery board ......USB code generated using STMCUBEMX
‎2018-05-21 4:12 AM
when I am sending data using USB, when the callback in my firmware gives me USB BUSY? i am using STM32F303VC discovery board ......USB code generated using STM32CubeMX.
Once, I received USB Busy state, dynamically sends correct data sometimes and sometimes i am losing data which i am sending...
here he is the code snippet.
i feel some issue with state change....
i am calling CDC_Transmit_FS(uint8_t* Buf, uint16_t Len) API fro two different places alternatively....
when i call from one place it is working fine....
issue arising when calling from 2 places akternatively
uint8_t CDC_Transmit_FS(uint8_t* Buf, uint16_t Len)
{ uint8_t result = USBD_OK; /* USER CODE BEGIN 7 */ USBD_CDC_HandleTypeDef *hcdc = (USBD_CDC_HandleTypeDef*)hUsbDeviceFS.pClassData; if (hcdc->TxState != 0){
return USBD_BUSY; } USBD_CDC_SetTxBuffer(&hUsbDeviceFS, Buf, Len); result = USBD_CDC_TransmitPacket(&hUsbDeviceFS); /* USER CODE END 7 */ return result;}
#usb-cdc-f3 #usb-busy-state-issue #cdc_transmit_fs #stm32f303- Labels:
STM32F3 Series
USB
‎2018-07-03 3:42 AM
This is Mohan and I too struggle on this issues can you get any other solution from this issues
‎2018-07-05 5:59 AM
Temporally you can use like this..
while(((USBD_CDC_HandleTypeDef*)(hUsbDeviceFS.pClassData))->TxState!=0);
CDC_Transmit_FS((BYTE*)&sentarray[0],count);- Mark as New
‎2018-07-06 8:14 AM
Hi ,
Thanks for your reply.I have implemented the solution,which you have describe in the previous post.but the solution is
not consistent . some times working and some times return USB BUSY state.Kindly provide another solution for this issue.
‎2018-07-06 9:25 AM
CDC_Transmit_FS (and underlying ST USB library) is not reentrant, do not call it from 2 places without protecton (a semaphore or whatever).
- pa
‎2018-07-09 1:55 AM
Could you please confirm is it possible reason for returning USB BUSY Flag,may be due to __HAL_LOCK state occurrence in the data packet transmission.
‎2018-07-09 1:27 PM
I don't want even start about their
__HAL_LOCK ... sorry. But yes.-- pa
‎2018-07-13 12:40 AM
along with that you can use this interface before
HAL_NVIC_DisableIRQ(USB_LP_CAN_RX0_IRQn);
__HAL_LOCK(hpcd);
and
__HAL_UNLOCK(hpcd);
HAL_NVIC_EnableIRQ(USB_LP_CAN_RX0_IRQn);in HAL_PCD_EP_Transmit () function.
this is ensuring while writing into USB transmit register to avoid USB RX interrupt
It is working for me without any data loss...
