Avgerinos
What are the possible Wi-Fi Modules to use with software support for STM32?
  • July 19, 2023
  • 0 replies
  • 944 views
Hello
I am looking for information about the available Wi-Fi modules that I can use for an IoT application, with software support (software drivers & examples for easy integration). The main application is to be able to connect to an MQTT server.
Looking at the development boards from ST, I have found the following:
- ISM43362 on dev board B-L475E-IOT01A
- EMW3080B on dev board B-U585I-IOT02A
The above modules have software support and examples through X-CUBE-CLD-GEN Expansion Package and X-CUBE-AZURE Expansion Package.
What are other possible Wi-Fi modules to choose for an IoT application?
Thank you in advance
