GTort.1
Using the Ble Module of the SensorTile.box on the Zephyr RTOS
  • March 2, 2022
  • 1 reply
  • 948 views
Hello, has anyone been able to use the Ble Module (SPBTLE-1S) of the STEVAL-MKSBOX1V1 (SensorTile.box) on the Zephyr RTOS?
We are struggling trying to configure the DTS and CONF files to be able to run a simple Zephyr BLE example:
https://github.com/zephyrproject-rtos/zephyr/tree/main/samples/bluetooth/st_ble_sensor
Below we provide our tentative (not working) DTS and PROJ.
Thanks in advance for any help.
prj.conf:
CONFIG_BT_SPI=y
CONFIG_BT_HCI=y
CONFIG_BT=y
CONFIG_BT_DEBUG_LOG=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME="SPBTLE-1S"
CONFIG_BT_GATT_CLIENT=y
app.overlay:
  chosen {
      zephyr,bt-hci-spi = &zephyr_bt_hci_spi;
      zephyr,bt-hci-spi-slave = &zephyr_bt_hci_spi_slave;
&spi2 {
  pinctrl-0 = <&spi2_nss_pd0 &spi2_sck_pd1 &spi2_miso_pd3 &spi2_mosi_pc3>;
  pinctrl-names = "default";
  status = "okay";
  cs-gpios = <&gpiod 0 GPIO_ACTIVE_LOW>;
  zephyr_bt_hci_spi: zephyr_bt_hci_spi@0 {
    compatible = "zephyr,bt-hci-spi";
    reg = <0>;
    irq-gpios = <&gpiod 4 GPIO_ACTIVE_LOW>;
    reset-gpios = <&gpioa 8 GPIO_ACTIVE_LOW>;
    spi-max-frequency = <1000000>;
    label = "SPBTLE-1S";
  zephyr_bt_hci_spi_slave: zephyr_bt_hci_spi_slave@1 {
    compatible = "zephyr,bt-hci-spi-slave";
    reg = <1>;
    1 reply
    RArte.1
    Have you fix the issue?
