USBX HOST printer example
ABasi.2
Hi!
i have managed to port the exisiting example of USBX device printer to the H563 micro and use it.
now i'm trying to do the same thing with the USBX HOST printer class.
but there are two problems:
1) there isn't an example
2) if i create a new project and select USBX HOST printer i think there are some missing files in the cube generation
for the device printer class  the cube generate  app_usbx_device.c app_usbx_device.h ux_device_printer.c and ux_device_printer.h
for the Host printer the cude generate only app_usbx_host.c and app_usbx_host.h
am i missing something?
my cube ide is 1.18.0 release
thank you !
FBL
Hi @ABasi.2
So far, no example is provided to cover Printer class. CubeMX imports Middleware files and leaves it to developer to tailor their application in app_usbx_host.c/h. Here is a suggestion to implement functions to initialize and communicate with the printer.
 * ux_host_printer.c
#include "ux_host_printer.h"
#include "ux_api.h"
typedef struct
	UX_HOST_CLASS_PRINTER *pPrinterClass;
} PrinterData_t;
static PrinterData_t sgrPrinterData;
bool ux_host_printer_IsPrinterConnected(void)
	bool bReturn = false;
	if (sgrPrinterData.pPrinterClass != NULL)
		bReturn = true;
	else
		/* No printer connected */
	return bReturn;
bool ux_host_printer_Send(uint8_t *_pData, uint32_t _iLength)
	uint32_t iSend;
	if ((sgrPrinterData.pPrinterClass != NULL) && (_pData != NULL))
		if (ux_host_class_printer_write(sgrPrinterData.pPrinterClass, _pData, _iLength, &iSend) == UX_SUCCESS)
			if (iSend == _iLength)
				bReturn = true;
			else
				/* Not all data has been sent to the printer */
		else
			/* Failed to send data to the printer */
	else
		/* No printer available or invalid parameter */
	return bReturn;
bool ux_host_printer_Receive(uint8_t *_pData, uint32_t *_pReceivedLength, uint32_t _iRequestedLength)
	if ((sgrPrinterData.pPrinterClass != NULL) && (_pData != NULL) && (_pReceivedLength != NULL) && (_iRequestedLength > 0uL))
		if (ux_host_class_printer_read(sgrPrinterData.pPrinterClass, _pData, _iRequestedLength, _pReceivedLength) == UX_SUCCESS)
			bReturn = true;
		else
			/* Failed to read data from printer */
	else
	return bReturn;
void ux_host_printer_AddPrinter(UX_HOST_CLASS_PRINTER *_pPrinterClass)
	if (_pPrinterClass != NULL)
		sgrPrinterData.pPrinterClass = _pPrinterClass;
	else
		/* Invalid parameter */
void ux_host_printer_RemovePrinter(void)
	sgrPrinterData.pPrinterClass = NULL;
Then, ensure your header file declares the necessary functions.
 * ux_host_printer.h
#include <stdbool.h>
#include <stdint.h>
#include "ux_api.h"
#include "ux_host_class_printer.h"
bool ux_host_printer_IsPrinterConnected(void);
bool ux_host_printer_Send(uint8_t *_pData, uint32_t _iLength);
bool ux_host_printer_Receive(uint8_t *_pData, uint32_t *_pReceivedLength, uint32_t _iRequestedLength);
void ux_host_printer_AddPrinter(UX_HOST_CLASS_PRINTER *_pPrinterClass);
void ux_host_printer_RemovePrinter(void);
When ux_host_event_callback is called in app_usbx_host.c, handle device insertion and removal as follows:
  switch (event)
    case UX_DEVICE_INSERTION:
      /* USER CODE BEGIN UX_DEVICE_INSERTION */
        if (current_class -> ux_host_class_entry_function == ux_host_class_printer_entry)
        	ux_host_printer_AddPrinter((UX_HOST_CLASS_PRINTER *)current_instance);
      /* USER CODE END UX_DEVICE_INSERTION */
        break;
case UX_DEVICE_REMOVAL:
      /* USER CODE BEGIN UX_DEVICE_REMOVAL */
    		ux_host_printer_RemovePrinter();
    	else
    		/* Another device is removed */
      /* USER CODE END UX_DEVICE_REMOVAL */
      break;
In MX_USBX_Host_Init, initialize host printer class after /* USER CODE BEGIN MX_USBX_Host_Init1 */
  /* Initialize the host printer class */
  if (ux_host_stack_class_register(_ux_system_host_class_printer_name,
		  	  	  	  	  ux_host_class_printer_entry) != UX_SUCCESS)
    /* USER CODE BEGIN USBX_HOST_STORAGE_REGISTER_ERROR */
    return UX_ERROR;
    /* USER CODE END USBX_HOST_STORAGE_REGISTER_ERROR */
I hope this helps! An internal ticket 208191 is submitted to CubeMX to add ux_host_printer.c and ux_host_printer.h in CubeMX generated code.
Best regards,
FBL
7 REPLIES 7
FBL
Hi @ABasi.2
 * ux_host_printer.c
#include "ux_api.h"
typedef struct
} PrinterData_t;
		bReturn = true;
	else
	return bReturn;
	uint32_t iSend;
				bReturn = true;
			else
		else
	else
	return bReturn;
			bReturn = true;
		else
	else
	return bReturn;
	else
 * ux_host_printer.h
#include <stdint.h>
#include "ux_api.h"
  switch (event)
        break;
    	else
      break;
    return UX_ERROR;
Best regards,
FBL
ABasi.2
Hello FBL
thank you for your kinde response and for the code
i will try!
best reguards!
Hello FBL
i have tried your code but it seems the printer is not enumerated
any guess?
thank you
Hi @ABasi.2
AFAIK, an example firmware will be available soon to cover this use case.
Best regards,
FBL
thank you FBL!
best reguards
Hello FBL
any news about the example?
thank you
Hello FBL
is there an expected date for teh example?
thank you
best reguards
