maxyork145
USB VCP Unknown Device
Posted on July 03, 2013 at 17:42
hi everybady
i have started an tutorial for UCB virtual com port (VCP), when the program start, alleways
Unknown device,
can help me
  * @file    app.c
  * @author  MCD Application Team
  * @version V1.1.0
  * @date    19-March-2012
  * @brief   This file provides all the Application firmware functions.
  * @attention
  * <h2><center>&copy; COPYRIGHT 2012 STMicroelectronics</center></h2>
  * Licensed under MCD-ST Liberty SW License Agreement V2, (the ''License'');
  * You may not use this file except in compliance with the License.
  * You may obtain a copy of the License at:
http://www.st.com/software_license_agreement_liberty_v2
  * Unless required by applicable law or agreed to in writing, software
  * distributed under the License is distributed on an ''AS IS'' BASIS,
  * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
  * See the License for the specific language governing permissions and
  * limitations under the License.
&sharpinclude ''usbd_cdc_core.h''
&sharpinclude ''usbd_usr.h''
&sharpinclude ''usb_conf.h''
&sharpinclude ''usbd_desc.h''
/** @addtogroup STM32_USB_OTG_DEVICE_LIBRARY
/** @defgroup APP_VCP
  * @brief Mass storage application module
/** @defgroup APP_VCP_Private_TypesDefinitions
/** @defgroup APP_VCP_Private_Defines
/** @defgroup APP_VCP_Private_Macros
/** @defgroup APP_VCP_Private_Variables
&sharpifdef USB_OTG_HS_INTERNAL_DMA_ENABLED
  &sharpif defined ( __ICCARM__ ) /*!< IAR Compiler */
    &sharppragma data_alignment=4
  &sharpendif
&sharpendif /* USB_OTG_HS_INTERNAL_DMA_ENABLED */
__ALIGN_BEGIN USB_OTG_CORE_HANDLE    USB_OTG_dev __ALIGN_END ;
/** @defgroup APP_VCP_Private_FunctionPrototypes
/** @defgroup APP_VCP_Private_Functions
  * @brief  Program entry point
  * @param  None
  * @retval None
int main(void)
  __IO uint32_t i = 0;
  /*!< At this stage the microcontroller clock setting is already configured,
  this is done through SystemInit() function which is called from startup
  file (startup_stm32fxxx_xx.s) before to branch to application main.
  To reconfigure the default setting of SystemInit() function, refer to
  system_stm32fxxx.c file
  USBD_Init(&USB_OTG_dev,
&sharpifdef USE_USB_OTG_HS
            USB_OTG_HS_CORE_ID,
&sharpelse
            USB_OTG_FS_CORE_ID,
&sharpendif
            &USR_desc,
            &USBD_CDC_cb,
            &USR_cb);
  /* Main loop */
  while (1)
    if (i++ == 0x100000)
      STM_EVAL_LEDToggle(LED1);
      STM_EVAL_LEDToggle(LED2);
      STM_EVAL_LEDToggle(LED3);
      STM_EVAL_LEDToggle(LED4);
      i = 0;
&sharpifdef USE_FULL_ASSERT
* @brief  assert_failed
*         Reports the name of the source file and the source line number
*         where the assert_param error has occurred.
* @param  File: pointer to the source file name
* @param  Line: assert_param error line source number
* @retval None
  ex: printf(''Wrong parameters value: file %s on line %d\r\n'', file, line) */
  /* Infinite loop */
  while (1)
&sharpendif
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
#usb-vcp
Tesla DeLorean
Guru
July 3, 2013
Posted on July 03, 2013 at 18:06
What version of Windows? What version of the Driver?
maxyork145
Posted on July 09, 2013 at 17:13
hello
you need to see the system_stm32f4xx.c
if you dont yous the good clock, the pc cant know the device usb
this is is the configuration used with discovery Stm32f4
  *        Supported STM32F4xx device revision    | Rev A
  *        System Clock source                    | PLL (HSE)
  *        SYSCLK(Hz)                             | 168000000
  *        HCLK(Hz)                               | 168000000
  *        AHB Prescaler                          | 1
  *        APB1 Prescaler                         | 4
  *        APB2 Prescaler                         | 2
  *        HSE Frequency(Hz)                      | 8000000
  *        PLL_M                                  | 8
  *        PLL_N                                  | 336
  *        PLL_P                                  | 2
  *        PLL_Q                                  | 7
  *        PLLI2S_N                               | NA
  *        PLLI2S_R                               | NA
  *        I2S input clock                        | NA
  *        VDD(V)                                 | 3.3
  *        High Performance mode                  | Enabled
  *        Flash Latency(WS)                      | 5
  *        Prefetch Buffer                        | OFF
  *        Instruction cache                      | ON
  *        Data cache                             | ON
  *        Require 48MHz for USB OTG FS,          | Enabled
  *        SDIO and RNG clock                     |
Tesla DeLorean
Guru
July 9, 2013
Posted on July 09, 2013 at 17:23
You need an accurate/crystal based clock source to meet USB specs, the RC based HSI won't get you there.
CAN also requires an accurate clock.
Were you using the wrong clock settings?
