Nickname14658_O
USB Joystick mouse: USB_Istr(); doesn't run: enumeration failed
  • March 19, 2012
  • 3 replies
  • 699 views
Posted on March 19, 2012 at 01:37
Hello;
I'm working on USB Joystick demo. It cant' run to this USB interruption, I mean when I set a breakpoint it does not work.
void USB_LP_IRQHandler(void)
  USB_Istr();
I have some questions, I'm new be in USB, and I need your help
1/ Which Step to follow when Enumerations fails, I need to khnow the steps for debugging.
2/ In this case How can I run interruption ?
Big Thanks
g@fsos
#breakpoint #usb_istr()
alok472
Posted on March 19, 2012 at 13:33
Normally the breakpoint shall be hit. Pls check that debugger selected is not ''simulator''
Which is the debugger you are using ?
alok472
Nickname14658_O
Posted on March 19, 2012 at 19:35
Thanks For your reply;
I'm using IAR and Jlink
