USB enable/disable pin on STM32F107
‎2010-10-23 2:32 AM
#stm32f107-usb-bootloader-working-without-pull-up-on-dp- Labels:
USB
‎2011-05-17 5:12 AM
Yes it is STM32F107. If I use USBUF02W6 as transceiver, then can I have problems to disconnect the device? It seems that to have a permanent internal D+ pullup. What transceiver do you suggest (NO BGA)?
Tank You- Mark as New
‎2011-05-17 5:12 AM
Are you talking about STM32F107, instead of STM32F017 ?
For STM32F107, D+ pull-up is integrated in the chip.
No extra port pin is required.
Tsuneo
‎2011-05-17 5:12 AM
USBUF02W6 (EMI filter w/pull-up) is not good for STM32F107.
D+ pull-up resistor isn't cut off on this chip.
STM3210C-EVAL for STM32F107VCT mounts EMIF02-USB03F2 (U4)
http://www.st.com/stonline/products/literature/um/15082.pdf
This EMI filter chip also integrates D+ pull-up, but the EVAL board leaves Rpu terminal NC.
These EMI filter/ TVS chip fit well for this purpose.
ON semi
NUF2030XV6
http://www.onsemi.jp/pub_link/Collateral/NUF2030XV6-D.PDF
NUP4016
http://www.onsemi.jp/pub_link/Collateral/NUP4016P5-D.PDF
etc.
For self-powered device, select a TVS chip without high-side diode on D+ line
High-side diode disturbs VBUS detection. VBUS voltage is kept high at disconnection, passing through this diode and D+ pull-up.
For example, some EVAL boards mount USBLC6-2 for self-powered device, but it's wrong choice.
USBLC6-2 (good for bus-powered, but not for self-powered)
http://www.st.com/stonline/products/literature/ds/11265.pdf
Tsuneo
‎2011-05-17 5:12 AM
I was curious if driving +5.0 V DC into PA9 while the microprocessor was powered down might cause a problem. So I gave it a try, but I was unable to damage the chip.
‎2011-05-17 5:12 AM
I had the same problem. I could not get the bootloader to connect without adding an external pull-up on USB_DP. However the real problem was with the USB_VBUS input on port PA9. My circuit dropped the voltage from +5.0 V DC to +3.3 V DC from USB_VBUS to PA9. The system memory (factory masked ROM) USB bootloer or USB hardware will not maintain a connection if the voltage on port PA9 is too low. I changed my circuit to allow the +5V DC from USB_VBUS to run directly to port PA9 and now the USB bootloader works without needing any external pull-up on USB_DP. There is an analog comparator circuit inside the microprocessor for monitoring the USB_VBUS voltage. I do not know at what threshold voltage the internal pull-up circuit will drop out. But +3.3 V DC is definitely too low.
The microprocessor I am using is the STM32F107VCT6 with a date code of 031 (or the 31 week of 2010).- Mark as New
‎2011-05-17 5:12 AM
On the datasheet, PA9 of STM32F107VCT6 is assigned to ''FT'' I/O level - ie. 5V-tolerant port. Usually, 5V-tolerant port is expected as partial-powerdown tolerant, too, by its structure. But the datasheet doesn't specify it. Usually, powerdown tolerance is shown as input leakage current at VDD = 0V. I don't see this parameter on the Electrical characteristics section on the datasheet.
Therefore, confirm it by asking to ST directly.
Do you mean you are connecting PA9 directly to USB VBUS (5V)?
You should have a protection resistor across VBUS and PA9, around 100k. With this resistor, leakage current is limited, even if the port would not be partial-powerdown tolerant.
Tsuneo
‎2011-05-17 5:12 AM
Q) Do you mean you are connecting PA9 directly to USB VBUS (5V)?
A) Yes, however my new circuit will have a 1k-ohm resistor and a capacitor to ground. ASCII Art: USB_VBUS ---/\/\/\/\---+---||--- Ground | +--- PA9
