STM32L053 USB with SYSCLK HSI16DIV
antonello
Posted on March 25, 2015 at 09:15
Greetings,
I'm developing an application using STM32L053 micro. I use usb device (composite hid, msc). When I  configure the system clock with HSI16, NO PLL  all DIVS to 1 everything works fine. Now I need to change this to run with HSI16DIV. (I simply change the HSI16DIVEN bit). Now the pc does not recognize the usb device any more.
I do not see why since my understanding was that HSI48 clock feeding usb shold be independent;
I post here the two configurations, the difference is in red:
This works:
   RCC_PeriphCLKInitTypeDef PeriphClkInit;
   __PWR_CLK_ENABLE();
   __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE2);
   RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI
      |RCC_OSCILLATORTYPE_LSE|RCC_OSCILLATORTYPE_HSI48;
   RCC_OscInitStruct.LSEState = RCC_LSE_ON;
   RCC_OscInitStruct.HSICalibrationValue = 16;
   RCC_OscInitStruct.LSIState = RCC_LSI_OFF;
   RCC_OscInitStruct.HSI48State = RCC_HSI48_ON;
   RCC_OscInitStruct.PLL.PLLMUL = RCC_PLLMUL_3;
   RCC_OscInitStruct.PLL.PLLDIV = RCC_PLLDIV_2;
   HAL_RCC_OscConfig(&RCC_OscInitStruct);
   RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_SYSCLK|RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
   RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;//RCC_SYSCLKSOURCE_PLLCLK;//RCC_SYSCLKSOURCE_PLLCLK;
   HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1);
   PeriphClkInit.PeriphClockSelection = /*RCC_PERIPHCLK_LPUART1|RCC_PERIPHCLK_I2C1
      |*/RCC_PERIPHCLK_RTC|RCC_PERIPHCLK_USB;
   PeriphClkInit.Lpuart1ClockSelection = RCC_LPUART1CLKSOURCE_PCLK1;
   PeriphClkInit.I2c1ClockSelection = RCC_I2C1CLKSOURCE_PCLK1;
   PeriphClkInit.RTCClockSelection = RCC_RTCCLKSOURCE_LSE;
   PeriphClkInit.UsbClockSelection = RCC_USBCLKSOURCE_HSI48;
   HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit);
This does not:
   __PWR_CLK_ENABLE();
RCC_HSI_DIV4
#stm32-stm32l0-usb-clock-hsi16div
0 REPLIES 0
