Stm32h753 Azure-rtos USBX two USB device classes
XLin.2
My project uses stm32h753 and Azure (ThreadX and USBX), I want to have USBFS as CDC and USBHS for DFU. In CubeMX how do I specify which USB interface is for which device class, or it should be done in code?
mohamed.ayed
Hi @XLin.2​ ,
Device with more than 1 port is not allowed by the spec and not supported by USBx
Use composite device is the correct way to expose multi functionalities on a single USB port
mohamed.ayed
Hi @XLin.2​ ,
